sticking brakes
after driving a short distance my brake pedal gets really hard and when i use the brakes they will stick.i thought the caliper was stuck so i removed it and tried to push it back in using a c clamp,but i couldn't budge it.so i removed the brake line from caliper and the caliper pushed back in easy.i replaced the master cylinder and the problem was solved.
but now after a month i'm having the same problem again,the pedal gets real hard and the brakes start sticking,could it be that the master cylinder is gone again(it was used) or is there some other problem?
