I've had my 4runner for about 2 years it has about 60000 miles on it. Recently it has started to over rev in 2,3,4 gear while under acceleration. Does this sound like the clutch is starting to slip. Has anyone else had this problem? What did you do to fix it? Any input would be appreciated.
Thanks
If it slips under accelration, the answer is YES. No, I do not own a 2000, and when you replace the clutch. Do not forget to replace the pilot bearing and resurface the Flywheel. Another thing to do, is to rebuild or replace the hydraulic slave cylender. kind of been there, done that, and fogot to do that?
