92 Si - Stock LS w/Turbo......now what?92HBsi 09-20-2005, 10:40 PM ok so i got the turbo and i'm running it at about 6-8 psi cuz i don't want to hurt the stock engine too much. i want to raise the boost but i don't know what to do next (really, i don't know shit about cars, i just got into this recently). I've asked some friends about what to do next and most come up with the same answer. Make it LS/VTEC.....BUT, i also hear thats not good for w/e reason (compression ratio). i've heard do some cam gears or sleeve it. Help, i don't want to make a mistake i'll regret later. CivicSpoon 09-20-2005, 11:37 PM Screw the cam gears, they are worthless. Sleeves, rods, and pistons. Then get a quality engine management system, or else all that engine work will be worthless. SiGNAL748 09-20-2005, 11:43 PM 12psi go. civickiller 09-21-2005, 04:08 PM depending on the size of your turbo, i would say go 10psi and see if you satisfied with that. your motor should be able to handle that, assuming tuned good Medabots 09-29-2005, 03:26 PM I recently blow my motor (Stock LS / T3 out of a sabb 900) I was running 11psi. That was fun, even when it last me two weeks. well, just get it tune before you push it to hard.. tunning is the answer!!! superbluecivicsi 09-29-2005, 04:19 PM Automotive Network, Inc., Copyright ©2012
