renault espace runningbri26 09-20-2005, 05:50 PM i have a renault espace txe c reg runs but runs rough i have tried new leads and plugs and it still runs bad the carb keeps popping unless u accelerate hard and this seems to be ok for a min then will carry on popping it is running idely at about 1500 revs could this be a timing / carb /or valve problem does anyone know what could be causing this. Smirn 12-05-2005, 06:17 PM i have a renault espace txe c reg runs but runs rough i have tried new leads and plugs and it still runs bad the carb keeps popping unless u accelerate hard and this seems to be ok for a min then will carry on popping it is running idely at about 1500 revs could this be a timing / carb /or valve problem does anyone know what could be causing this. Air leak, check the manifold gasket, base plate gasket. Automotive Network, Inc., Copyright ©2012
