tire pressure for 88 z24
russ54
09-19-2005, 01:05 PM
does anyone know what the tire pressure should be on a88 z24 for 215/60x 14?
OverAllComa
09-19-2005, 05:35 PM
Tire pressure is not dependent upon the car, but on the tires. Check the sidewall, is should say "'x' PSI MAX."
Ryan066
09-19-2005, 06:00 PM
30-32psi. dont put the max pressure in the tire... will cause it to weather crack and such, maybe a little more wear in the middle of the tire.
most cars have the recommended PSI for the car on the door pillar.
OverAllComa
09-19-2005, 07:01 PM
Yes...they do have the reccomended PSI on the car itself, but that's for OEM tires. I really doubt he has those.
Ryan066
09-19-2005, 08:34 PM
true.
those numbers sounds pretty stock anywho.
90% of tire pressure for cars is 30 psi .. couple psi really dont make htat much difference.
russ54
09-20-2005, 02:17 PM
:confused: yeah mine is missing on the door panel and the owners manual tells you to look there?
cdru
09-20-2005, 02:44 PM
What does OEM or non-OEM tires have to do with it? It's the weight of the vehicle that sets the recommended pressure, not the size of the tire (under normal circumstances).
Ryan066
09-20-2005, 04:33 PM
save the hastle and put them to 30.
