headlight removalaccord 96 05-12-2002, 01:46 PM I'm trying to remove my OEM headlights from my 1996 accord V6 to install my projectors. I have the corner light removed, as well as the grille and the bumper lights. I have (5) 10mm bolts removed, the light is loose in the opening, but I can't seem to get them out... I have pulled and pushed, but since this is the first mod I am doing I have no idea what i am doign wrong.. Any help would be greatly appreciated! :confused: JayFidizzy 05-12-2002, 01:48 PM check all the way to the back of the light...if they bolted it down similar to my car there is one more bolt that is behind the fender. You are going to have to pull back the cover in the wheel well to get to it. sickhonda 07-31-2002, 07:46 PM I have a 91 Honda Accord and also having difficulty removing my OEM headlight. There are two screws under the headlight housing and the one attached to the grill that are not easily accessible. Anyone, please HELP!!! kings_blend 03-31-2003, 09:42 PM I am having troublt taking off the corner lights on my 92 accord, i wanna put on some clear croners but cant get the stock ones out??? I unscrewed the one screw on the top and cant seem to get it off, the manual says to undue that one screw and take it off but i aint havin no luck. hondacivic4drlx 03-31-2003, 10:08 PM take opff the bumper and then all hidden bolts will be revealed sickhonda 04-01-2003, 09:56 AM Originally posted by kings_blend I am having troublt taking off the corner lights on my 92 accord :D You're on the right track, after removing the top screw, you just have to pull it harder straight towards the front of the car. A bit sticky because of the years of build up and the rubber moulding around it, plus two prongs holding it in the rear of the assembly to keep it in place. You can just twist the light sockets off afterwards. YOU ONLY NEED TO REMOVE THE FRONT BUMPER WHEN REPLACING THE HEADLIGHT ASSEMBLIES. Good Luck! Automotive Network, Inc., Copyright ©2012
