Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 09-15-2005, 05:44 PM   #1
grappler119
grappler119's Avatar
grappler119 Normal reputation
A/C Compressor will not turn on
Need some help please. I do not here the a/c compressor cutting on when I turn on the a/c. I checked the fuse and it isa good and the vacum is working fine. I also repalced the conrol swith and still nothing.. Need some help on where to go from here...
grappler119 is offline   Reply With Quote
Old 09-15-2005, 07:08 PM   #2
Bads Crew
Bads Crew's Avatar
Bads Crew Normal reputation
Did you try jumping the wire at the low presure cut off? Its the switch that is on the drier. The big silver canister. Just pull the conection off and jump a wire across the plug. If it starts it is caused by a low charge. Don't run it with the wire jumped.
Bads Crew is offline   Reply With Quote
Old 09-15-2005, 07:36 PM   #3
grappler119
No did not do that but I did recharge the coolntand aand it turn on fine but now there is another problem... I is leaking like a son of a.....Where do I start to try to isolate and repair leak?
Old 09-15-2005, 08:38 PM   #4
Bads Crew
Bads Crew's Avatar
They sell a dye that you put into the system. It will mark the leak. If your leaking bad you are going to need a pro to service it. After the repair is made the system needs to have a vacumm pump put on it before its charged.
Old 09-16-2005, 09:39 AM   #5
grappler119
Thanks, do you have any idea how much that would cost?
Old 09-17-2005, 01:18 PM   #6
dmbrisket 51
dmbrisket 51's Avatar
dmbrisket 51 Normal reputation
Send a message via AIM to dmbrisket 51
Re: A/C Compressor will not turn on
if its a bad leak, you shoule be able to hear it, if you can mark it with a paint marker, if the system was dead for a day or longer (more then 24 hours) you will need a new accumulator or you will just have more problems in the long run, it will not be cheep, but as long as its not the evap in the dash it wont be to expecive either.. the professional shop oil/R134A will be the expencive part of the whole thing
dmbrisket 51 is offline   Reply With Quote
Bookmarks
Google
Web AF
