truck turns over no crankjsbama1 09-14-2005, 10:03 PM 2000 s-10 extreme (flex fuel) new fuel pump and filter @ 60,000 mi. another pump and filter @ 124,000 - truck has 125,000 now only 1000 mi. on new pump. acts like fuel pump again. Starting fluid in the intake and it runs fine on this. Some days runs some days does not. Anybody have any clues. Thanks dmbrisket 51 09-17-2005, 02:12 PM where is pump from? jsbama1 09-18-2005, 06:57 PM 2000 s-10 extreme (flex fuel) new fuel pump and filter @ 60,000 mi. another pump and filter @ 124,000 - truck has 125,000 now only 1000 mi. on new pump. acts like fuel pump again. Starting fluid in the intake and it runs fine on this. Some days runs some days does not. Anybody have any clues. Thanks NAPA auto parts jsbama1 09-18-2005, 06:58 PM where is pump from? NAPA dmbrisket 51 09-18-2005, 10:14 PM ok, you should be good on the pump then, not garenteeing it, but napa sells quality stuff, if it would of been an autozone pump i would of told you to take it out and replace it with a napa one... but you should get a pressure tester and see whta kinda pressure your putting out on your 2 second prime charge to make sure its up to snuff jsbama1 09-21-2005, 12:38 PM ok, you should be good on the pump then, not garenteeing it, but napa sells quality stuff, if it would of been an autozone pump i would of told you to take it out and replace it with a napa one... but you should get a pressure tester and see whta kinda pressure your putting out on your 2 second prime charge to make sure its up to snuff Thanks will try that this weekend Automotive Network, Inc., Copyright ©2012
