2001 T&C Error Codes P0700 & P0740
hortonm
09-13-2005, 06:04 PM
My check engine light just came on - stopped at autozone and am getting P0700 and P0740 error codes. I suspect the Solenoid pack - can probaby pick one up - any ideas other than the dealer?- is it tough to replace? I plan to replace the fluid and filter (ATF+4) - Is this fluid still only available at the dealer?
GTP Dad
09-13-2005, 07:22 PM
Even though you have the codes take it to a tranny shop and get them to check it for you. There are a lot of problems with Chrysler minivan transmissions. Changing the solenoid pack is not really a do it yourself job but you may also have a problem with the trans control unit. You should be able to get ATF+4 at any autoparts store along with a filter.
tonymacchiaroli
11-06-2006, 09:14 AM
Have you foud out the cause of the P0740 error code. What was the solution to your problem? My engine check light is coming on and I have P0700 and P0740 error codes.
