Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 09-13-2005, 03:44 PM   #1
Syc
Syc Normal reputation
Clutch Adjustment
I recently got a 2003 Cavalier coupe (base model). It is a manual transmission. I have never had as much trouble with a manual transmission as I have with this Cavalier. How can I adjust it?
The problem that I am having is that it seems there is only about 1 - 2 inches of play between the clutch being enganged and not be engaged. With the pedal pressed to the floor, I bring the pedal up almost all the way out before it will start to engange and then there is the 1 - 2 inches and then all the way out and i am in gear and moving. I do nothing but make teh car jerk back and forth when I am starting out in 1st gear and 2nd gear. 3rd gear through 5th is not a problem.
I just need to to get more play in the clutch rather than the 1 - 2 inches that it has. I have driven several manuals and I have never had this problem before (accepted when i was learning at age 12).
Syc is offline   Reply With Quote
Old 08-25-2008, 09:21 PM   #2
Zeifer
Zeifer Normal reputation
Re: Clutch Adjustment
Hydraulic clutches auto adjust themselves. Essentially when the clutch catch is high up, you need a new clutch. My Cavalier is doing that, and while I like that small area where it catches, it needs a new clutch.
Zeifer is offline   Reply With Quote
Old 08-26-2008, 09:59 AM   #3
Classicrocjunkie
Boosted Grocery Getta!!
Classicrocjunkie's Avatar
Classicrocjunkie Normal reputation
Send a message via AIM to Classicrocjunkie
yea, you probably need a new clutch. My engagement point is about 2 inches off the floor.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2004 Pontiac Sunfire Coupe SE Getrag 5 speed
2009 Subaru Impreza WRX 5-door
www.Rdfabs.com
Classicrocjunkie is offline   Reply With Quote
Old 08-26-2008, 07:15 PM   #4
mcalkins3
mcalkins3 Normal reputation
Send a message via AIM to mcalkins3
also you could have a small leak in the internal slave. Make sure your fluid is to the top, and you could try to bleed it. If its had an air pocket in it and it could cause issues shifiting. Cheap, and easy try. Otherwise the clutch kit is pricey.
mcalkins3 is offline   Reply With Quote
Bookmarks
Google
Web AF
