Idle Control Valve, clean or replace?JOAT 09-13-2005, 11:58 AM Just curious if anyone has had any luck cleaning the idle controller. It's on a 93 Voyager LE with the 3.3l and A604/41TE. Mine intermittantly, approx 2-3 times a month, allows the van to stall when warm, no codes. I swapped it with my identical 93, and the problem followed. GTP Dad 09-13-2005, 07:28 PM Remove it and spray with throttle body cleaner. You may also want to remove the throttle body and clean it too. This will help with the idle, just don't move the pintle when you have the IAC valve out of its location. JOAT 09-14-2005, 01:15 PM Thanks, I'll give that a try. Automotive Network, Inc., Copyright ©2012
