95 intrepid cooling fansraccoonfl 09-13-2005, 10:25 AM '95 Intrepid electrical problem. Cooling fans not operating properly. Is there any way to direct wire the fans for "always on" (Florida climate) that might possibly help the constant overheating problems...... snr8715 10-13-2005, 10:18 PM '95 Intrepid electrical problem. Cooling fans not operating properly. Is there any way to direct wire the fans for "always on" (Florida climate) that might possibly help the constant overheating problems...... Yes, I wired mine to stay on anytime the switch is in the run position. I took power from the fuse box inside the car. The blower motor fuse. Run a fusible wire to the hot wire from blower motor fuse and ground the black wire to the frame, and fan stays on with engine running all the time. I didn't cut any wires, go to napa and get 2 yellow connectors and splice the wires in. Pull the low speed relay and leave the high one in. Automotive Network, Inc., Copyright ©2012
