idles bumpy and rides sputterystarzzss 09-11-2005, 06:23 PM 1994 dodge grand caravan se...............new fuel pump, fuel filter, spark plugs, wires , coil pack. when idle engine is really bumpy, when driving sputters. any ideas. thanks, starzzss caravandrvr 09-11-2005, 10:34 PM 1994 dodge grand caravan se...............new fuel pump, fuel filter, spark plugs, wires , coil pack. when idle engine is really bumpy, when driving sputters. any ideas. thanks, starzzss Check your alternator using the procedure outlined here: http://www.automotiveforums.com/vbulletin/showthread.php?t=398005 http://www.automotiveforums.com/vbulletin/showthread.php?t=419359 Rottweiler28 09-12-2005, 06:53 PM I have the same problem as yourself and have also tried what you have, I have been looking into many things now and many sources are pointing me towards checking the Egr, Map, mass air flow sensors, pcv and timing if all that fails to work. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
