A/C problem
SpeedRacer12
09-10-2005, 02:23 PM
I have a problem with my a/c. Everything in the car works perfect. I turn on the heat and it works fine, but when I turn on the A/C it still is warm air. I checked the engin and all the belts are working fine and the fan is on too. I don't kno what else it could be. Any Ideas?
mazdatech177
09-15-2005, 02:47 PM
more than likely you are simply out or refrigerant. carry it to your local mazda dealer and get them to check it out.... if it did all leak out they will likely recharge the system and add a flourescent dye for leak detection in the future... the ac may work normally for a few days/weeks until the r134 leaks out. if you do have a full system charge of r134 then it is most likely an electrical problem.... that would of course take some diagnosing
SpeedRacer12
09-15-2005, 04:27 PM
hey thanks, but where would the refrigerant be located? Could it be a fuse problem also if i have a 25fuse in a 20?
skidbrown
09-28-2005, 12:07 PM
the fuse would not cause a problem unless your blowing the fuse. However for the sake of safety you should place the correct fuse in.
the r134a is located inside the a/c system (hoses and such)
