Bolt pattern numbers?dugie6551 09-10-2005, 09:59 AM What is the wheel bolt pattern number for a 1st gen. S10 (84')? I have seen in magazines 5"x4 1/2", 5"x4 3/4" & 5"x5". Which one do I have ? OverBoardProject 09-10-2005, 12:14 PM I believe that it's 5 x 4 3/4" though I'm not positive It isn't 5 x5" or 5 x4 1/2" It's the same as a comaro The first number refers to # of holes not inches, But I'm sure that you knew that already dmbrisket 51 09-10-2005, 02:45 PM 5x4.75, 4.5 i beleve is a ford small hub OverBoardProject 09-10-2005, 03:40 PM your right Doug. Mustangs, and I believe Rangers too. + they fit AMC, and 5 bolt Dodge cars dugie6551 09-11-2005, 06:38 PM The first number refers to # of holes not inches, But I'm sure that you knew that already Yeah I knew that ... I had a "brain fart" when I was typing. :lol: Thanks for the replies. I know the pattern is the same as Cameros and also Oldsmobiles. I am looking into new rims so I needed to know what bolt pattern to use. OverBoardProject 09-11-2005, 10:16 PM I kinda like those rims that you can use on both Ford and Chevy (dual pattern) if you can find a set that you like. They're nice to have if you get another vehicle and easier to sell later dmbrisket 51 09-11-2005, 11:24 PM ^^ thats how mine are, 5x4.75 and 5x4.50 OverBoardProject 09-12-2005, 12:11 AM The wheels that I have for my 1 old hotrod have little plates that go under the lug's which allows me to switch. Those wheels were made in the early 70's and I bought them from the first owner. They're still mint but only 14" xboxdave13 03-09-2007, 05:49 PM i found a set of rims and tires online but the bolt pattern is in mm. not in. so my question is would a 17 x 7 Universal 10H (PCD 5x100/114.3) +40 Offset 73 Center Bore fit onto a 95' s-10? Automotive Network, Inc., Copyright ©2012
