1996 How to replace Speed Sensor
JohnFrisco
09-08-2005, 03:54 PM
I just bought a Speed Sensor online for $25. The dealer wanted $171 for it!
I know it goes in or on the transmission? Does anyone have details on how to replace the sensor?
Thanks!
John
1996 Nissan Altima GXE Automatic
JustSayGo
09-08-2005, 05:33 PM
Hopefully you have a VSS for an auto trans. There is $100 differance between a VSS for a manual trans and one for an automatic. From underneath the car near the starter and half-shaft unplug the sensor and remove the bolt with 10mm socket or wrench. Pull the sensor out of the transmission. Use vasoline or ATF on the new O-ring and put the new sensor in the same way. Connect the the wire.
JohnFrisco
09-08-2005, 05:52 PM
JustSayGo,
Thanks a lot for the info! Yeah I got the VSS for automatic. Here (http://www.rockauto.com/catalog/catalog.php?carcode=1210611&parttype=8664&partGroup=33&EPImodelID=19561&EPIengineID=2768) it is.
Thanks again,
John
JustSayGo
09-08-2005, 08:31 PM
Good Deal! I am certain that six mos ago the best prices I found were $40 and $140. All three sensors are easy to change from underneath. I think there are only two wire connector plugs near the starter. One goes to the starter solenoid, follow the other to the VSS. Push the VSS into the trans by hand. Useing the bolt to push it in can break the ear off of the sensor. O2 sensor instructions are, don't use sealer on the threads that doesn't say O2 safe. There may be some approved type of sealer on the threads already.
Chevy.Arnold
02-12-2009, 08:43 PM
Hey I'm facing the same problem.... i am struggling to take the speed sensor off. It seems stuck. I unplugged wire and took the bolt off. i tried to pull it off but idk why it wont pull right off. What am i doing wrong?
