01 Caravan only blows on highpatarusky 09-08-2005, 03:10 AM Does anyone know if the resistor issue on the '97 to '99 Vans is still the problem on the 2001's? It worked fine until yesterday. Now I have only the high speed working. A/C and heat are fine just no slower speeds. Does anyone know if the resistor location is the same as well? Thanks theFREAKnasty82 09-08-2005, 03:13 AM yes, if you only have high speed, it will 9 times out of 10 be a resistor problem and you'll need to replace to resistor pack. REDSFILTHY 09-16-2005, 01:50 AM The resistor pack is located behind the glove box on the 2001's. Empty the glovebox and pull in on the tabs on each side to swing the door down. You'll see a connector with 8 wires on it. Pull the connector and remove the 2 screws to release the resistor pack.It is about 16 bucks at the Chrysler dealer. Automotive Network, Inc., Copyright ©2012
