Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 09-07-2005, 08:04 PM   #1
cathys0715
cathys0715 Normal reputation
AC problems!
Hi All,
I've searched this forum and can't find the answer to my problem...so here it goes.
We bought a 95 Blazer LT 4x4. AC runs hot so took it to the mechanic. It had too much freon in it so they vacuumed it and put the correct amount in. Still not working. The mechanic thinks it may be an electrical problem somewhere. He ran out of time and wants me to bring it back so he can "trace wires".
My husband looked at it, the compressor is not kicking on at all. There is apparently a censor that will keep it from kicking on if the freon level isn't right....but the mechanic did fix that. Husband also said the clutch that is mounted to the compressor in not engaging. So, I'd love to get some opinions before we go pay another $70 for diagnosis. My husband fixes A LOT of stuff on our vehicles and he'll read your replies to see if he can tackle this one (I pray so!)!
Thanks in advance!!
cathys0715 is offline   Reply With Quote
Old 09-07-2005, 08:10 PM   #2
Jeremy Fitch
Jeremy Fitch Normal reputation
Send a message via Yahoo to Jeremy Fitch
Re: AC problems!
Originally Posted by cathys0715
Hi All,
Thanks in advance!!
The switch you are speaking of is the low presure switch. You can pull the plug on this switch and jump the 2 connections over with a peice of wire, just stick each end of a short wire into each side of the plug, and see if the compressor kicks on. If it does then the pressure switch is bad.
Jeremy Fitch is offline   Reply With Quote
Old 09-07-2005, 08:13 PM   #3
cathys0715
Re: AC problems!
Thanks for the quick reply! Husband is going out to see about that right now!
Cathy
Old 09-07-2005, 08:17 PM   #4
cathys0715
Re: Re: AC problems!
Husband needs to know, is the low pressure switch located in front or on the back of the compressor?
Cathy
Old 09-07-2005, 08:25 PM   #5
s10blazerman4x4
s10blazerman4x4's Avatar
s10blazerman4x4 Normal reputation
Send a message via AIM to s10blazerman4x4
Re: AC problems!
Are there any wires on the accumulator itself?Not sure as to location of that switch as no parts show for that year vehicle on autozone but on my 91 i have a connector on the accumulator
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3--> If GM engineered something to fail on this beast it has or will. Repairs include w/in first 30 days of owning it: P1870, left front wheel bearing, gas cap, rad cap, idler tensioner, seat handles, and the list goes on.
http://www.automotiveforums.com/vbul...d.php?t=890449
Chime in ^ with any suggestions.
s10blazerman4x4 is offline   Reply With Quote
Old 09-07-2005, 08:30 PM   #6
cathys0715
He said there are two plugs on the compressor itself...one in the front and one in the back. There is also a plug and wires on the accumulator itself. What's his next step?
Cathy
Old 09-07-2005, 08:38 PM   #7
s10blazerman4x4
Re: AC problems!
http://www.automotiveforums.com/vbul...ressure+switch
Old 09-07-2005, 08:41 PM   #8
s10blazerman4x4
Re: AC problems!
Old 09-07-2005, 08:46 PM   #9
97BlazerDude
97BlazerDude's Avatar
97BlazerDude Normal reputation
Re: Re: Re: AC problems!
You want to jumper the round switch on the accumulator. Have the AC on MAX. Jumper the sensor on the wire, not the contacts on the accumulator.
I can wear a blazer. I can drive a blazer.
97BlazerDude is offline   Reply With Quote
Old 09-07-2005, 08:47 PM   #10
cathys0715
Eureka! He found it, thanks to yall! It's the accumulator switch. The clutch kicked on when he put the screwdriver to the connector part...does that make sense? Anyway, he said that's what it is...now just to get the part from Autozone!
Cathy
Old 09-07-2005, 08:48 PM   #11
s10blazerman4x4
Re: Re: Re: Re: AC problems!
Good thing you know for sure i threw them threads out there because it talks about that in quite detail
Old 09-07-2005, 08:49 PM   #12
cathys0715
Oh no, he just said "not to the accumulator but to the connecting wires"
When he put the screwdriver THERE the clutch kicked on.
Cathy
Old 09-07-2005, 08:49 PM   #13
s10blazerman4x4
Re: AC problems!
Anytime i can help a Southern it makes my day.We will rise again.
Old 09-07-2005, 08:52 PM   #14
cathys0715
Thank you!! This is exactly what made the fan clutch kick on...so please help us out some more....what is the NAME of the part that needs replacing? Accumulator switch or sensor wires...or what?
Cathy
Old 09-07-2005, 08:54 PM   #15
cathys0715
Haha! I am really a Texan...geographically in the South but not all SOUTHERN But I am sure yall will rise again anyway
Seriously thanks for the quick replies
Cathy
Bookmarks
Google
Web AF
