engine problems, HELP!
kidkaotik
05-09-2002, 08:03 PM
having a problem w/ my engine, there's loud pounding rhythmic noises coming from the crankshaft area, and i'm not sure what's causing it. i have checked the flywheel, as well as the crankshaft (still attached to the block), couldn't see any visible problems, can anyone help? thanks!
ivymike1031
05-09-2002, 10:06 PM
One idea that comes to mind is that you've got a bad bearing (conrod most likely, perhaps main)... but before you tear down the engine and check that, take a look at your TV damper (it's built onto the crank nose pulley). Those guys can wear out & break, and that'd make a racket too.
