1997 Dodge Diesel- Acting Weird!Randy Wicks 09-06-2005, 11:16 AM My 1997 diesel 3/4 ton needs help! Here are the symptoms. sometimes when keyed its just clicks after several tries usually will start. ALso sometimes after it starts it makes a horrible whining , grinding noise sounds like from the starter. When it does this also it will not shut off! WHen i turn the key off it simply keeps running making that noise. Any help is apprieciated. red1ton 09-11-2005, 02:18 AM sounds like the starter soloniod is sticking causing the starter to run all the time. that is where the whinning sound is coming from. hope it helps john4.7 11-15-2005, 10:48 PM You don't need to buy a whole starter in some cases. You can just get the contacts for it. Automotive Network, Inc., Copyright ©2012
