help
Janet Harris
09-05-2005, 11:53 PM
What ic the color code for a 1998 ford contor, like where does green go to the right speaker or the left? I need all the color codes because body cut mine off and now i cant connect my new radio. Please help me.
It is a 1998 ford contour
hallboy
09-10-2005, 08:23 AM
I can't find my book. I ssume that you meant the body shop cut your wires.
The best way if you can't get a diagram may be to pull a door panel to see what side has what color. Also if you just need the speaker info hook every thing else up get your power and use straight wires instead of the harness to locate the speakers so you will have sound. Once you find what side is what you can connect the wires up correctly and then use your harness.
Good luck to you.
