09-05-2005, 01:47 PM
2.8lV6 3800V6 swap
Im getting a late 80s early 90s blazer not sure what year excatly. It needs work. It has the 2.8l v6 and its not running right. I have a 88 bonivelle with the 3800v6. What would you need to do the swap from the 2.8l to the 3800? I have everything from the bonnivelle( the computer fuelpump etc)
09-05-2005, 03:03 PM
AF -Advisor
Re: 2.8lV6 3800V6 swap
no, period.
1995 Factory Blazer Service Manual for sale, PM if interested.
09-05-2005, 07:03 PM
Is it possible to do?
09-05-2005, 08:05 PM
AF -Advisor
Comon, one is a front wheel drive engine and the truck is a rear wheel drive vehicle.
You do the math.
09-05-2005, 09:19 PM
Does it make a difference that the engine came out of a front wheel drive car? I don't see why that would matter. I would be changing the trans and the moutmounts.
09-05-2005, 09:20 PM
Re: Re: 2.8lV6 3800V6 swap
Yes makes a world of differance, 2 different kids of transmissions. It simply will not work.
09-05-2005, 11:30 PM
Does the trans bolts up different or something? I plan on putting a 700r4 in if possible.
09-06-2005, 12:23 AM
AF -Advisor
Drop it, it isn't going to happen. Not unless you want to spend $7000 custom fabricating everything to make it fit.
09-06-2005, 08:46 AM
I just want to know why it wouldn't work?
09-06-2005, 04:20 PM
If you researched your question at all...anywhere, let alone compared bolt patterns between the tranny you want and the engine you want/have - you wouldn't be here asking these questions. It simply will not work. Completely different driveline, PCM, body modules, the works. Swapping and taping stuff together like one could do in the past is pretty much done and gone in this age of purpose built, specifically engineered vehicles. Engine/driveline/computer swaps tend to still work, but only within VERY narrow margins. What you are proposing is not even on the map. If you're going through the trouble and expense of getting a 3.x V-6 in a 2.x Blazer, 1st generation - Consider a fully blown LS1 V-8 conversion. That just bolts right up with a mild swap of sensors and a donor computer. Have fun!
09-07-2005, 02:59 PM
If you had the rear wheel drive 3.8 from the buick it would work.Head over to www.advanceadapters.com
They sell everything needed for the swap only if it is rear wheel drive motor from the Buick if not your out of luck.
If anyone doubts this i can scan page from this book i am reading.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3--> If GM engineered something to fail on this beast it has or will.  Repairs include w/in first 30 days of owning it: P1870, left front wheel bearing, gas cap, rad cap, idler tensioner, seat handles, and the list goes on.
http://www.automotiveforums.com/vbul...d.php?t=890449
Chime in ^ with any suggestions.
09-07-2005, 03:00 PM
