Power Window Motor Assembly
I to replaced the driver door window motor, but I opted to just replace the entire assembly as opposed to just the motor because it looked complicated, but even that was a two day adventure with plenty of tense moments,and threats to get rid of the car.
I have the shop manuals now and can understand a little more. In your case it says to drill a hole through the window regulator and sector gear. Install a bolt and nut to lock the gear and case in place, then remove the motor bydrilling out the rivets. Installation is in the reverse ,but don't forget to remove the bolt and nut. I guess you are past this point if you already removed the motor. This could be the reason you are having trouble re-installing the track.
