no gauges are workingstuckey_fun 09-04-2005, 10:23 PM hi, i have a 93 intrepid. the tech, spedo, fuel, and temp gauge are not working,but if i open the glove box they start to work for a sec. then qute so then i pull the glove box light out unplug the light and jump the two wires then every thing starts to work .but it then blow the interiors light fuse. when that blows the raido and powers miorrs dont work but they should cause they have there owen fuse. i have no intrior light .then when i put everything back the way it should be the light on the info center for the low washer light is real dim. i dont know what to do now any help AWP9521 09-05-2005, 12:18 PM I'll take a guess and say you have a bad ground connection for the Dash. yentzer6 11-21-2005, 06:31 PM [QUOTE=stuckey_fun]hi, i have a 93 intrepid. the tech, spedo, fuel, and temp gauge are not working,but if i open the glove box they start to work for a sec. then qute so then i pull the glove box light out unplug the light and jump the two wires then every thing starts to work .but it then blow the interiors light fuse. when that blows the raido and powers miorrs dont work but they should cause they have there owen fuse. i have no intrior light .then when i put everything back the way it should be the light on the info center for the low washer light is real dim. i dont know what to do now any help[/QUOTE i also have a 93 dodge intrepid doing same thing right down to the low washer fluid light after takeing it to garge after garge and lots of money it turned out to be the BODY CONTROL MODULE Automotive Network, Inc., Copyright ©2012
