1998 F-150 Service Engine Lightbinkleyk 09-04-2005, 10:21 PM I have a 1998 F-150 with the 4.3 and I keep getting a Service Engine Light with the code of #1 Cyc Missfire, I have put new wires, Plugs, and it still gives me that code. Any Suggestions????? peppermrj 09-05-2005, 12:09 PM I have a 1998 F-150 with the 4.3 and I keep getting a Service Engine Light with the code of #1 Cyc Missfire, I have put new wires, Plugs, and it still gives me that code. Any Suggestions????? How's it run? Did you disconnect the battery since you did repairs? binkleyk 09-05-2005, 12:51 PM Yes I have reset it several times but it seems to come back, I even used the scan tool to reset it after each repair, still comes back, the truck runs good I just can not understand why it comes back. Thanks for the reply obxcars 09-05-2005, 04:22 PM is there a coil pack for each plug? try switching coil packs see if the code comes back to cylinder 2. If so you need a new coil pack. binkleyk 09-06-2005, 03:49 PM There is only one coil pack, not one for each plug, I how ever have been thinking about changing the coil pack anyways. obxcars 09-08-2005, 06:13 PM its probably not the coil pack. next cloged injector. I fix a 98 windstar with Cyl. 1 misfire. it was bad injector. coil pack 80.00 to 100.00. injector 40.00 to 50.00 binkleyk 09-08-2005, 10:54 PM Never thought about the injector, thanks I will try that this weekend. Automotive Network, Inc., Copyright ©2012
