1985 318i engine cuts out - need help
When driving for about 5-10 minutes the engine just cuts out like someone turned off the fuel. Most of the time if you wait 5-10 minutes the car will restart and run for anywhere from 2-10 minutes before doing this again.
I have checked the fuel pumps and believe them to be ok because I have fuel pessure (checked with a good guage). I also have good spark at this time too, but no signal to turn on the injectors.
I have the Bently book and have been through most everything in it with no improvement.
The one thing I have noticed is that if I pull the connector off the air flow switch unit the car will start, but runs very rough. When putting this connector back on the engine rpm increases for a few seconds and then dies and is back to the same state as before.
I am getting so frustrated with this as it's not like I have not tried to check as much as I can, but with parts costing so much I can't just start putting on new parts.
Please help!
Dick
