I just changed mine on a 1993 5spd. If you reach above the gas pedal, you will see and feel a rod going from the clutch pedal to that point. right above that is a hook, if you reach toward the firewall from that hook you should feel a bracket. the bracket is hooked to your clutch cable. just push the clutch pedal in and hook it up.
