Changing the headlight assembly on a 99 TahoeTina K 09-04-2005, 05:28 PM I am trying to change the headlight assembly on my 99 Tahoe. Is there anything difficult that I need to know before starting on this project? TRANSFORMDEZIGN 10-01-2005, 11:24 AM I am trying to change the headlight assembly on my 99 Tahoe. Is there anything difficult that I need to know before starting on this project? THAT'S AN EASY ONE.TAKE OUT THE PARKING LIGHTS & UNSCREW THE SOCKETS.YOU MUST TAKE OFF THE GRILLE,IT'S LIKE 5 SCREWS MOST ARE ACROSS THE RADIATOR PANEL, AND ONE SCREW IN THE GRILLE GOING TO THE CENTER SUPPORT. THEN THE GRILLE IS CLIPPED IN AT THE BOTTOM. LIFT UP THE TABS & SLIDE THE GRILLE OUT. THEN YOU SHOULD SEE THE 4 BOLTS THAT HOLD ON THE HEADLAMPS.A 20MIN JOB IF THAT. Automotive Network, Inc., Copyright ©2012
