Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 09-04-2005, 12:20 AM   #1
timothy47129
timothy47129 Normal reputation
1992 cavalier brake problems
I had a wheel cylinder leaking so replace both my rear wheel cylinders,brake shoes and bleed them.My brakes still didn't work untill the pedel was 2inches from the floor.So I replaced my front brake pads and bleed all four brakes.My brakes stop good but I still have ecessive pedel travel(2"from the floor).So how do I tell if it is the power booster,master cylinder or the ABS system?My abs light is not on. Im thinking it is the master cylinder.There isnt a special way to bleed brakes with ABS is there?
thanks,
Tim
timothy47129 is offline   Reply With Quote
Old 09-04-2005, 07:16 PM   #2
quake61
quake61's Avatar
quake61 Normal reputation
Re: 1992 cavalier brake problems
thanks,
Tim
if abs or brake light isnt on means u dont have a major problem there
just make sure u bleed them right and no air is in the lines
also check and make sure u refill the reservoir till it says max
and cap is on tight
after all that is done,,if the car stopps right that rule out the booster
and abs
just check beeding and reservoir level
quake61 is offline   Reply With Quote
Bookmarks
Google
Web AF
