Front Brake Pad Replacement Instructionsbiphnest 09-03-2005, 02:47 AM Does any have instructions on how to replace front brake pads on a 2003 Sequoia? Thanks. cz75b40 09-03-2005, 08:44 PM Front brake pads as well as rear brake pads are quite easy to do on Sequoias. Couldn't find a site specifically on Sequoia's but here are two sites that might help you out. http://www.atomineer.com/redmx5/mod_brakes.html http://www.danoland.com/nsxgarage/brakes/frontpads/frontpads.html There is a bit difference between this set-up and yours. But it follows the same principles. Just remember SAFETY is first. Make sure your SUV is on a flat surface and well supported with jack stands. I've done my pads twice and used brake pads from Auto-Zone for about $20 and the good thing is that they're lifetime. Also expect to have your rotors turned. Pep-Boys will turn them for about $7 here in So. Cal. but only if they have the appropriate width. Hope this helps you out. Automotive Network, Inc., Copyright ©2012
