Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon > 2nd Gen 00-05
Old 09-03-2005, 01:31 AM   #1
Yellow02NeonLE
Yellow02NeonLE Normal reputation
Check Engine Light, Car Running Rich???
i recently had a performance exhaust system installed on my 2002 neon. I went with an obx-r header and downpipe, magnaflow hi-flow cat, 2.25 piping and a straight-thru style muffler...just something cheap i had around. Ever since i have had a check engine light, and i know this has to do with the o2 sensors reading different temperatures and oxygen readings because of the backpressure changes, but im going through a lot of gasoline, and im seeing a lot of carbon building up on my bumper just above the muffler... im wondering what i can do to get my car running a little bit better... im thinking about getting a new muffler in a few days, looking into a mugen style twin loop muffler... but who knows... im hoping for now that the msd ignition coil and performance wires along with some new plugs should help clean the exhaust up... or so im hoping... any insight to this problem feel free to ask.... any other questions for me about my car... feel free to ask me...
c_g_I_l_r_o_y@hotmail.com
Yellow02NeonLE is offline   Reply With Quote
Old 09-03-2005, 03:05 AM   #2
ricebike
ricebike Normal reputation
Re: Check Engine Light, Car Running Rich???
hmm, did you read the actual codes & reset the ECU to see if the codes return?
ricebike is offline   Reply With Quote
Old 09-03-2005, 10:09 AM   #3
das2123
Tuning Neons since '97
das2123's Avatar
das2123 Normal reputation
Send a message via AIM to das2123 Send a message via Yahoo to das2123
How do you know this, did you read the codes? There are no backpressure changes in your car, that is a huge misconception. The MSD coil pack and wires won't do anything performance wise for your car. The MSD is a stock coil pack painted red, granted it looks nicer and is cheaper, but it won't do anything performance wise. Read the codes doing the key dance and let us know what you get. To read any OBD codes, perform the following sequence.
1)Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds.
2)Count the number of times the 'Check Engine' lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32. The last code you should get is 55, which is end of codes.
To cycle the ignition key ON means to turn it only as far as it takes to get the dash lights to respond. It does not mean to crank the engine.
das2123 is offline   Reply With Quote
Old 09-03-2005, 07:51 PM   #4
ricebike
Re: Re: Check Engine Light, Car Running Rich???
wow, das...
I didn't know u can do that on OBD II cars... i know it worked on my obd I dodge shadow & plymouth K car (when i had those POS)...
I'd just go str8 to autozone for a free scan... & they can also reset codes using the scanner!
Old 09-04-2005, 03:29 AM   #5
Yellow02NeonLE
i have had the car in for a tuneup recently and they checked the diagnostic codes... error code 21 was indicated....
-------> 21 = o2 sensor problem (oxygen sensor), upstream or down stream
upper sensor is in the 4-1 collector in the header... lower o2 is in the downpipe just before the cat.... the stock system had the lower o2 located in the cat....
Old 09-17-2005, 06:31 PM   #6
vamc
vamc's Avatar
vamc Normal reputation
They only seem to work on neons and a few other dodge cars NOT all obd2 computers. IE.honda,chevy.
vamc is offline   Reply With Quote
Bookmarks
Google
Web AF
