Keyless entry programming problemspmeaster 09-02-2005, 11:24 PM I've searched and found the basic programming instructions for the 03. Mine doesn't react the same way...the locks cycle (up and down) and gives a short horn beep EMMEDIATELY after I turn it ON, OFF, ON, OFF. And when I release the unlock switch it does it again. What does this mean? I got my 03 used and it didn't come with remotes (it was a repo). How can I tell for sure if it even has a receiver and is set up for keyless entry. Seems that it's acting like it does if it responds (albeit incorrectly) to the programming in this manner. TIA! Schurkey 09-03-2005, 05:30 PM Do you have remotes? Have you gone through the whole procedure yet? Try it, see what happens. Only takes about a minute--minute and a half. pmeaster 09-03-2005, 05:33 PM Yeah, I actually have 4 remotes, 3 number Ones and 1 Number Two. I went through the entire procedure, but nothing happens when I hold down the buttons (I hold it down for nearly a minute to be sure) and I changed all the batteries. Schurkey 09-04-2005, 11:11 AM My experience is limited to two Trailblazers, and both had at least one remote to begin with. Sorry I can't help more. Onblsht 09-04-2005, 04:46 PM Do you have the correct remotes for your Trailblazer? They have to be the MYT3X6898B remotes, not LHJ011 like many people have listed wrong on ebay. eyeofstorms 09-06-2005, 04:56 PM i have the same problem with my truck..i dont know what it means..but i need help i have the MYT3X6898B remotes...i did the same on,off,on,off then it beeps and locks and unlocks..after i held the lock and unlock bottons down the truck does a lock cycle.."like it should do right?" then i turn the truck on to exit the program mood and try the keys and they dont work.. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
