Working on the tune up.therealrayman 08-31-2005, 12:33 PM Where is the fuel filter located and what tools do i need to replace it? sorry for all the threads but i figured it would be easier for everybody is i used different threads for different subjects. D-Bo 08-31-2005, 03:06 PM its attached to the pump, which is an in-tank pump. i installed a walbro pump in my car, here's what i did. you basically have to follow the same instructions. http://www.cardomain.com/ride/692648/7 ghostchild316 08-31-2005, 03:28 PM dummy he meant the fuel filter not the fuel pump strainer.You'll need a phillips screw driver and prolly new lines too since most likely they will be seized on the filter or you'll tear them trying to undo them. just follow the lines back from the injectors and you should be able to spot it D-Bo 08-31-2005, 03:39 PM honest mistake Automotive Network, Inc., Copyright ©2012
