IMa Dubass Oil problem I think?
HiT-TheNos420
08-30-2005, 11:36 PM
Since i accidently filled my oil an inch pass the max line My engine seams to not hum anymore while idoling. And when I take off from a stand still, the take off seams sorta bumpy, but I could just not be giving it enough gas at the begining but it is a noticable change. Is it the Oil I overfilled?
Thor06
08-31-2005, 12:12 AM
I dont know, you should drain out some oil and see.
l_eclipse_l
08-31-2005, 12:16 AM
:thinkerg:
ez1286
08-31-2005, 12:22 AM
If the oil is overfilled the crank will hit the oil creating a lot of drag not to mention foaming the oil. Drain the oil asap.
macder
09-01-2005, 10:21 PM
Drain some oil ASAP! To much oil will destroy your rear main seal causing oil to get on your clutch. I'm not even going to get into other problems this will cause.
Black97GST
09-01-2005, 10:30 PM
i just have question..... how did you fill your oil up an inch over the MAX line??? thats like a whole quart or more too much.
HiT-TheNos420
09-02-2005, 02:10 AM
well, my oil gage wasnt working, but i didint know it at the time, and I put in 2 qaurts. I read the oil stick wrong, it was in the dark too lol. But I just got my oil drain today and I put in a new KN 1010 oil filter and a new fram air filter(only till i buy a KN air filter kit) and Mobil 1 syn. So i should be alright untill I buy my intake.
Black97GST
09-02-2005, 03:41 PM
so did it fix the problem?? hopefully??
