GT28 Turboleestewart 08-30-2005, 08:03 PM Anyone in here running the GT28 turbo from a stock S-15 engine?? If so feedback would be appreciated. I'm trying to decide on a trubo for my SR. I do not want to top mount. sidewayzS13 08-30-2005, 08:50 PM ive been looking into the new garret the gt2871r i belive it is check out enjuku NiSmO_zt 08-30-2005, 09:23 PM wow, an $1100 turbo, holy pants R.W.240 08-30-2005, 09:30 PM Anyone in here running the GT28 turbo from a stock S-15 engine?? If so feedback would be appreciated. I'm trying to decide on a trubo for my SR. I do not want to top mount. Average HP Number - 280ish WHP Cams, Tune, 1.2Bar - 320ish WHP Id do everything else first with the T25 (Standalone, Manifolds, Injectors) to get it above the 250WHP mark and then get a Spec-R T28 and Tomei 256s... as a matter of fact... thats exactly what im going to do once I get the rest of the car perfect. T28 - 7-800$ Stock S15 Ball Bearing GT28 - Dunno much about it... its a T25 Turbine with a big compressor I think GT28RS - The Bandwagon Turbo. Sport Compact has it. Same max Hp as Stock S15 orestes 08-31-2005, 02:00 AM 2 things. 1 i thought the s15 jsut had a t28 not gt28 2 also i thought the gt28rs maxed at like 350hp+ driftking777 08-31-2005, 09:42 AM yea you def quoted some miss info on the Disco Patatoe (gt28rs) very good turbo...goes to around 350hp...not much higher than that though...The S-15 spec-R T28DD is topped around 320whp....GT28RS is a way better buy...and if you have another $300 to spare...take no short cuts and get the gt2871r...excellent turbo...quick spool up and high WHP #'s...good to 400hp...depending on the A/R you decide to go with... R.W.240 08-31-2005, 12:52 PM yea you def quoted some miss info on the Disco Patatoe (gt28rs) very good turbo...goes to around 350hp...not much higher than that though Last I Checked SCC was shifting to a bigger turbo because the RS was maxed out at around 280WHP... I dont really follow what the GTRS can do though. The S-15 spec-R T28DD is topped around 320whp.... If you have a T25 with bolt ons (Exhaust,FMIC,Intake,Fuel Mods) The S15 BB will make around 280WHP. once you add Cams, ECU, and Manifolds the T28 will make around 320 at 1.2bar driftking777 08-31-2005, 01:42 PM If you have a T25 with bolt ons (Exhaust,FMIC,Intake,Fuel Mods) The S15 BB will make around 280WHP. once you add Cams, ECU, and Manifolds the T28 will make around 320 at 1.2bar I personally think that if you going to be doing all that...you might as well get something alittle better than just a stock turbo...becuase soon enough you'll have to reflash the ECU becuase your gonna want another turbo anyways...and why would you boost a stock turbo to 1.2 bar anyways...thats what 15psi...anywho...i just like the sound of a gt2871r turbo anywho...i guess im impartial though. and btw its never good to max a turbo...if your going for a 320 range...go for something that maxes at 320hp...going for 350...go for 400..ect ect...just better for the turbo...unless you want to replace it often Automotive Network, Inc., Copyright ©2012
