WRX vs STIwoodenit 08-30-2005, 11:21 AM Moving out to Arizona and will be traveling on alot of dirt back roads. Is there a major difference in off-road performance, other then speed, between the WRX and the STI? Thanks, TJ freakray 08-30-2005, 11:29 AM The WRX will be more comfortable as it will have slightly softer suspension. If you're going to be going off road, why not consider the Legacy 2.5 XT woodenit 08-30-2005, 12:40 PM Because I REALLY like the look of the WRX and I plan to use all of it's performance. I was told that the STI's suspension is beefier and made for the rigors of off road use, yes? TJ freakray 08-30-2005, 02:18 PM NO. The STI's suspension is made for high performance on road driving. Where did your info come from? woodenit 08-31-2005, 11:15 AM I read it in one of the mags, C&D, Motor Trend...? one of them. They said that because of the added strenght, they would be able to perform better on the gravel.... SkylineMan32 09-04-2005, 12:22 AM In theory the WRX's higher suspension and slightly softer spring rate is ideal for off roading, while like freakray said the STi although percieved as a rally car, the US version is more tuned for like tarmac hillclimbs, or autocross. Automotive Network, Inc., Copyright ©2012
