New yet notfiberglasscivic 08-28-2005, 03:47 AM I just bought my second civic. It's been awhile since I had my last one but I have a couple of Q's. I have a 93 lx. I want to remove my gov and rev limiter (don't ask why). I saw what happened last time someone asked and I wasn't impressed on how you treated them. I just want a straight and simple answer to my question. The other question I have is, my idle RPM's when the car is cold, are close to 400 - 500. It's almost slow enough to stall the car. Other than adjusting the idle what other causes of low idle are there for that engine? blackcomet 08-28-2005, 06:26 AM To take off your rev-limiter, you can simply plug a lap-top to if you have the program for obd1 and the wire ofcourse and you can pretty much change everything from there...As for your idle..well I don't have an rpm gauge but I could here my engine goin down that low once in a blue moon so I just give a shot of gas and it goes back up. snowman2005 08-28-2005, 07:17 PM check ur timing and plugs for ur idle might also be ur fast idle valve or w/e its called(not quite sure how to mess with that one). as for ur "governer" and rev limiter the only way ur gona get rid of ur rev limiter is if u chip ur ecu(not worth it for and lx) and u dont have a speed limiter. and no u cant just plug a laptop to ur ecu to modifie things. check out www.pgmfi.org on how to chip ecus the right way ssoratokad 08-28-2005, 08:48 PM my car does the same thing in cold weather, i wouldnt worry about it. fiberglasscivic 08-31-2005, 12:45 AM The low idle is more than just a cold weather prob. Thanks for the link to PGMFI. I need to look into all this a little more thourghly. I'll create another thread once I'm done experimenting. Ace$nyper 08-31-2005, 02:18 PM To take off your rev-limiter, you can simply plug a lap-top to if you have the program for obd1 and the wire ofcourse and you can pretty much change everything from there. I'd agree there get chrome if you plan on tuning I think its the best program i've worked with. fiberglasscivic 09-02-2005, 12:08 PM Yeah but from everything I've read I will still have to chip my ECU. Is that correct or will chrome allow me to change the values for all my tables without chiping. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
