Originally Posted by badassfocus1101
how did u put in the flip kit? do u have to cut the frame???? caz im wantin to lower my 88 f-150.. and i figured flip kit would be a good way
Well, I originally bought a flip kit which is just two matching seperate pieces of metal bent in the shape of a C or U, with a hole in the middle to align it to the axle.
What I did was rented a big jack(Big jack as in one size up from a little two ton) and set of jack stands to accomadate the bigger jack. I jacked it up from under the ring and pinion(I don't know if this is good but that's what I did) and put the stands under the frame. Leaving the Jack in place, I removed my leaf springs, jacked the axle up some more and re-attached them underneath the axle with the C-joints or whatever they are called C-brackets or something. Thats all. The factory C-bracket is welded on the top of the axle. You could flip your axle over, but then you would have to drive in reverse to go forward. And the alignment to the drive shaft would be off to.
And I drove around for a while with the front up in the air cause I couldn't lower that myself. I have noticed other guys driving around like that and wonder if they have done the same thing or they've got air bags or hydrolics. Anyway it doesn't take long, a couple hours. You have to remember to test drive it after you get it down and then tighten the U-bolts again when you get back from the drive.
