everything seemed to point to the crank sensor, so while checking for voltage I found 5.8 volts running through the GROUND wire ( center ) in the harness going to the crp sensor. Further checking showed 5.8 volts on all grounds going to temp sensor, cmp sensor, ecm, the whole works. Figuring there was a ecm problem, or a pinched wire that would be impossible to find, I ran a fused wire from the ground to the firewall ground strap. The jeep started right up after 2 months of no fire. This jeep isn't in great shape, and the owner doesn't want to put anymore $$ into it to fix it right. thanks to all who sent info.......
