timing chain questions86 rustbelt 08-26-2005, 02:24 AM got all the parts, ready to put back together, question on rtv. should rtv be applied to both sides of timing cover gasket, one side, or just around the bolts? also the oil pan, i have a cork gasket, does it need rtv applied to it also, or will the cork gasket be sufficient GDBSKE 08-29-2005, 04:18 PM You really don't need rtv at all unless you need it to hold the gasket in place. If you didn't pull the head I could see that you might need it to hold the gasket in place. sl88toyo 07-26-2007, 09:26 PM I have 88 pickup 22RE 4 cyl. Does it have timing chain or is it a belt. KimMG 07-29-2007, 02:37 AM I have 88 pickup 22RE 4 cyl. Does it have timing chain or is it a belt. Instead of hijacking a two year old thread, start your own. Generally threads work better when they are about one vehicle. To answer your question, your pickup has a timing chain. fourwd1 08-08-2007, 11:14 AM I have 88 pickup 22RE 4 cyl. Does it have timing chain or is it a belt. 22R/RE has a chain, not a belt. BDF_19 09-19-2007, 01:07 PM i got a 92 with the 22-re in it how hard is it to take the timing cover off and do you need to pull the oil pan off?? Automotive Network, Inc., Copyright ©2012
