Some1 Help Me Newbie240sxstock 08-26-2005, 12:22 AM well just to let u know i have a 1990 240sx stock everything,its has 85,000 miles..........iight let me get to the piont.i had it for a 1year and 6 months...runs real good till last night....well it started in the moring when i was driving it started to make a nosie like something is loose or broke but a noise that would get louder then lower but it drived real good like normal....but that noise..it came for the back of the engine..on the side of where the starter was....and other thing i needed to get a power steering flush...badly makeing noise when i turn the wheel....ok...just to let u know....well then i started it at night and guess what..i started up and i pust on the gas and i heard this loud noise in the mid section of my car right under me a loud noise..and when i let off the gas it dies on me...i do the same thing it starts then ..let go of the gas and goes dead..with that loud ass noise right under me...and its auto.i wlll post picsof my car tomm...can some body let me know something..i mean somebody that works on nissan 240sx..help..please????????????? R.W.240 08-26-2005, 01:21 AM What was the noise? if it was a damn loud clacking that means your bearings are TOAST. If you use pounded bearings for long enough eventually the car will do the start and die routine (amid lots of noise) thats really all I can think of... I dont think Auto KA24s make enough power to crack ring lands. Loud Noises - prolly the bearings getting loose Cruisin Around on if for a day - Beating the shit out of loose bearings Firing up the car the next morning - no oil pressure on shitty bearings = spun bearing(s) Lots of spun bearings - Firing Sputtering then dying. If the "loud Noise" was clacking Id drain the oil and look for metal shavings (or chunks)... If you spun the bearings that horribly then you'll need a new motor. AWDSR20 08-26-2005, 11:45 AM there is a bushing for the drive shaft. look and see if its worn out. the bushing (looks like a doughnut) is between the first drive shaft and the second one. when wormn out, it causes noice and vibration right under the center of the car. Waltz 08-26-2005, 08:18 PM might also wanna do the diagnostic on your auto tranny (yes there is one) pretty complicated thought if you want to know it just let me know at Destroyer_xiii@hotmail.com i have the schematics at home messenger would be an asset too as it is real time best of luck nissanfanatic 08-26-2005, 10:48 PM Check engine/transmission mounts. They are garbage on every automobile released that sports a KA engine. Even old minivans with SOHC KAs most often have crapped out engine mounts. Dying is common on 240s with IACV related problems. Check out www.240sx.org for more on the typical problems associated with 240sx's. Automotive Network, Inc., Copyright ©2012
