Which wire from ecu is rpm/tach signal?puna2k 08-25-2005, 11:09 PM I have a 94 civic del sol with a d15 motor. 1st my cars interior is all gone except seats and str. wheel, no dash no gauge cluster,no harness . I want to hook up my aftermarket tach, to the rpm/tach signal wire from the ecu, but i dont know which one. don't just say the blue wire it won't help. I need a pinout diagram and wire location. thanx E Honda 08-26-2005, 12:45 AM You do not need to go to the ecu for the tach install. There is a blue wire al by iteslf over by the master cylinder........Most have a plug on the end with a black rubber thing holding it in place. It will not be connected to anything. CivicSpoon 08-26-2005, 02:09 PM Pin A21 x_outlaw_x 08-31-2005, 09:03 PM CivicSpoon 08-31-2005, 09:31 PM ^^^ READ BEFORE YOU POST. He said that he removed the wiring from behind the dash and gauge cluster. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
