94 Taurus SHO has no powersblaess 08-25-2005, 08:22 PM I drove my 94 SHO home from work with no problem. When I went to take my daughter to Cheer class, I had no power whatsoever. I immediately jumped the car with our van, but still no power inside. I took a multimeter to the battery and I had 12 volts. When I took teh key out of the ignition, I could here a clickinh noise in the trunk. I found the noise coming from the keyless entry module. I checked all the fuses and they were good, so I pulled out the one that controlled teh keyless entry - still no power. Any suggestions? shorod 08-25-2005, 11:25 PM If you took your multimeter to the battery and had more than 9 volts, maybe you have a loose battery cable or a bad ground. -Rod Automotive Network, Inc., Copyright ©2012
