97 lx Brake pedal low
quickywd01
08-24-2005, 12:16 PM
Hey, The brake pedal is low and the pads are good along with the shoes in the rear. What could be the cause of this?
chevyn0va1
08-24-2005, 03:09 PM
check fluid level? maybe master cyl is leaking?
AzTumbleweed
08-24-2005, 07:11 PM
Bad power brake booster.
quickywd01
08-25-2005, 12:06 PM
Fluid checked and perfect. Didn't notice any leakage of brake fluid.
quickywd01
08-25-2005, 12:07 PM
Can you give more details. Does it need to be replace or serviced? Anything I could do to get it going again?
chevyn0va1
08-27-2005, 10:43 PM
i was told once if you hear a swish noise when you push the brake pedal then that inidcates booster or master cyl If your not comfortable with this kind of a job leave it to a pro.
KimMG
08-28-2005, 01:29 AM
rear brakes may need adjusting
quickywd01
08-29-2005, 08:18 PM
My father found a shop that will do the work cheap so he said he's going to take it there. I'll update you guys on what happens.
