Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > F Series
Old 08-23-2005, 08:35 AM   #1
mngixxer
mngixxer Normal reputation
91 f150 voltage guage bounces, vehicle wants to die after driving for awhile.
I have a new battery in it, had the alternator tested and it tested good. What else could it be? Once its been running for awhile, the amps drop down damn near to the 8 mark on the guage - if ya turn ac on, it drops further.
Thanks,
Scott
mngixxer is offline   Reply With Quote
Old 08-23-2005, 12:02 PM   #2
Austin8214
Austin8214's Avatar
Austin8214 Normal reputation
Re: 91 f150 voltage guage bounces, vehicle wants to die after driving for awhile.
Thanks,
Scott
Check and clean all of your grounds.
Austin8214 is offline   Reply With Quote
Old 08-23-2005, 12:58 PM   #3
mngixxer
Re: Re: 91 f150 voltage guage bounces, vehicle wants to die after driving for awhile.
How many grounds are there? Sorry I sound kinda stupid on this but I didnt see a whole lot of them.
Old 08-23-2005, 01:25 PM   #4
Austin8214
Austin8214's Avatar
Re: Re: Re: 91 f150 voltage guage bounces, vehicle wants to die after driving for awhile.
For starters check the negitive cable that runs from your battery to the engine block. Also have you had any work done to your truck lately? Other that insalling the new battery.
Old 08-23-2005, 01:28 PM   #5
mngixxer
The only negative that come off the battery goes to something that is run off the main belt -- its not the alternator and grounds out onto it is a brand new cable. No - not that I know of. I just got done doing a tune up but the truck was like this prior to me doing a tune up.
Old 08-23-2005, 11:13 PM   #6
BULLITTR6
BULLITTR6 Normal reputation
Send a message via Yahoo to BULLITTR6
I was going to suggest maybe the voltage regulator, but the book I have says your truck has an internal regulator in the alternator, and you said it tested good. That is unless you have the optional 165 amp alternator, which has the regulator on the back of it.
If your truck starts and runs good, I would guess you have a bad connection to the guage or a bad guage. Really, the charging system is pretty simple, as in not many components. I would agree with a bad ground connection.
Good luck and please update.
1991 F350 dually w/ 7.3 deezal
2008 Mustang GT
1993 Rodeo LS w/ 3.2 v6, 2wd (daughters)(Now totalled)
1991 Yamaha XT600
1993 Honda CR250R
Hard tellin', not knowin'
BULLITTR6 is offline   Reply With Quote
Old 08-24-2005, 07:07 AM   #7
mngixxer
The truck doesnt always start good. if its warm, it has a hard time starting which is leading me to believe it might be a coil bad on it. Once it sits and cools down - she fires right up. A buddy of mine also stopped by last night and said check your cap and rotor cause if thats cracked, it can also be acting up like that.
Scott
Bookmarks
Google
Web AF
