1999 Mazda 626 keyless remote programming instructionsMarilyn Teach 08-21-2005, 11:14 PM Does anyone have keyless remote programming instructions for a 1999 Mazda 626? My remote is #GD7D-675DY. thanks mazdatech177 09-07-2005, 05:03 PM open drivers door, insert key in ignition, turn ignition from lock to on three times pretty quickly dont start engine. take key out of ignition and push driver door ajar switch in three times. this is located in the door jam and has a rubber cover over it. after doing this you should hear 2 beeps. you are now in program mode. press the unlock button on any remotes you have. you can press all the buttons for good measure ;) make sure you have all the remotes present at time of prgramming, programming one will render all other useless and in need of programming. oh, make sure you have all other door and trunk and hood shut when doing this Marilyn Teach 09-07-2005, 08:33 PM open drivers door, insert key in ignition, turn ignition from lock to on three times pretty quickly dont start engine. take key out of ignition and push driver door ajar switch in three times. this is located in the door jam and has a rubber cover over it. after doing this you should hear 2 beeps. you are now in program mode. press the unlock button on any remotes you have. you can press all the buttons for good measure ;) make sure you have all the remotes present at time of prgramming, programming one will render all other useless and in need of programming. oh, make sure you have all other door and trunk and hood shut when doing this Thanks so much for the instructions. It worked like a charm. The dealership was going to charge $75/hr to program an extra remote :screwy: Automotive Network, Inc., Copyright ©2012
