Re: Need some repair help !
You have removed the big nut from the center of the crank and the 3 or 4 nuts that hold the pully on, right?
All balancer puller kits I have seen come with a variety of bolts with different threads, and one of these sizes always works. If you have bought or borrowed a kit, I suspect it is incomplete and some bolts are missing.
Try a tool rental place. It's cheaper than buying a puller.
Or try this:
You should be using 2 or 3 of the bolt holes that were exposed when you unbolted the pully. Therefore, the bolts you removed from the pully will be the right thread. You can easily match up that thread size in a longer bolt.
