93 Saturn SC - Hesitating initial acceleration - Need Help
Webgas
05-05-2002, 12:25 AM
I have a 93 Saturn SC 1.9. It hesitates (stales, no power for 1 sec then kicks in) during initial acceleration. I have changed the fuel pressure regulator. It drives fine after it gets up to speed. Sometimes stalls in the intersection when I start up again. Have any suggestions as to what the problem might be?
Thanks for your help.
Randy D
webgas@worldnet.att.net
Tireburner
05-14-2002, 01:03 PM
Try cleaning the mass air flow sensor and the throttle body with carb cleaner (spray) and see if that resolves the problem.
Saturn
10-31-2002, 08:03 AM
I have a 97 SC2 and the same thing happens to me....When I hit the gas It takes a second, then the RPM's go way up then the car picks up speed, so the total time from when I hit the gas to when the car actually picks up some speed is about 4 seconds. I went to the Saturn dealership here in Orlando, FL. and one of the guys said check for a clogged filter. If thats not the answer to the hesitating acceleration, it's most likely just that you are only going to get so much response from a 4 cylinder. I dont know about the stalling though. I have an automatic.
Green-SC2
07-15-2003, 03:43 PM
I have a 93SC2 with the same problem I cleaned throttle body and replaced the map sensor, and it still stalls occasionally in intersections.
99sc1
07-15-2003, 11:36 PM
check the spark plugs, when the dealership powerwashed my engine or whatever ya call it, the spark plugs got wet and caused acouple problems , including delayed acceleration
