Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 08-20-2005, 03:21 AM   #1
ex voto
ex voto Normal reputation
Send a message via AIM to ex voto
New member... 1996 Lumina Brakelights
I searched my query, but I didn't find a straight and direct answer... maybe I'm an idiot and searched incorrectly.
Anyhoo, I just bought a 1996 Lumina for next to nothing. Everything works, and I'm going to put tires on it and charge the A/C and drive the car as my daily (I have four motorcycles and a 91 Honda Civic EX autocross car for fun).
My problem is the brakelights... the highmount works, but the two lower lights work intermittenly. Actually, they work rarely. I replaced the bulbs (they worked for ten minutes), checked the fuse (didn't do anything), and changed the fuse (same as changiong the bulbs).
Is there an easy fix for this? I believe I read something about the turn signal switch. Could that be my problem? Should I try and re-work the flippers (I know... weird term. I'm an old-school Corvette guy at heart) to get the brakelights to work?
Thanks in advance to all.
ex voto is offline   Reply With Quote
Old 08-20-2005, 08:11 PM   #2
Manny_boy
Manny_boy's Avatar
Manny_boy Normal reputation
Your turn signal switch is going bad... your third brake light being the only working one is a common symptom - your two lower brake lights are routed through your turn signal switch. Common GM problem. See the link below for a discussion of how to solve your woes:
http://www.automotiveforums.com/vbul...ht=turn+signal
Manny_boy is offline   Reply With Quote
Old 08-21-2005, 01:43 PM   #3
ex voto
Re: New member... 1996 Lumina Brakelights
Fantastic! Now, I have a better problem... what do I do about the airbag? Is there an easy way around that?
Old 08-21-2005, 02:27 PM   #4
cadgear
cadgear's Avatar
cadgear Normal reputation
Airbags are a piece of cake. Disconnect the battery (that should be the first step with any electrical repair). Unplug the fuse, remove the bag via two torx bits on the back of the wheel, and disconnect; the only thing you have to keep in mind is once the steering wheel is off, DO NOT turn the shaft. Its WAY too easy to lose center for the SIR coil.
Just be smart about things and you won't have an airbag in your face.
cadgear is offline   Reply With Quote
Old 08-23-2005, 12:42 AM   #5
zephram22
zephram22's Avatar
zephram22 Normal reputation
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
A relay maybe? Or you may have a short somewhere.
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
zephram22 is offline   Reply With Quote
Old 08-23-2005, 11:25 AM   #6
ex voto
Re: Re: New member... 1996 Lumina Brakelights
Hrm... I'll see what I can come up with. I'll work on getting the airbag and steering wheel off and let you guys know.
Thanks for all of your help!
Old 08-23-2005, 05:02 PM   #7
Manny_boy
Manny_boy's Avatar
This is a common, well documented problem with GM multifunction switches, click on the link above.
Bookmarks
Google
Web AF
