90 runner with starting problem finally fixedkrc333 08-19-2005, 05:44 PM Well after two weeks at the shop they found out i had a bad plunger. Originally they thought it was the contacts in the starter or a bad starter in general, but after replacing both i was still having the same problem. I know the problem of getting in and nothing happening outside of the dash lights working while turning the key is a common problem. Brian R. 08-19-2005, 07:29 PM Thanks for providing that update. One question that comes to mind is Why didn't changing the starter fix the problem? Wouldn't changing the starter give you a new plunger? krc333 08-22-2005, 01:42 PM I'm not sure to be honest with you. It was a rebuilt starter that i put in, but according to my guy he said the plunger wasn't coming up. Brian R. 08-22-2005, 05:54 PM It's likely the problem with both starters were sticking solenoid contacts. The plunger would behave like that. krc333 08-22-2005, 06:33 PM Well he changed the soleniod contact first and he was pretty surprised when that didn't fix the problem. Automotive Network, Inc., Copyright ©2012
